Will Forerunner 945 work with Varia Vision?
There are no instructions on how to get it to work. I get it to pair but it's not syncing screens
on a Fenix 6pro it does work
with a few restrictions
sad to see it is marked as discontinued product
happy & safe sporting
This was helpful. I updated from 2.3 to 3.6 but now when it turns on i get to the acknowledge screen and then it won't let me acknowledge then it reboots? Any suggestions?? How do you acknowledge??
tap it
it reboots because you pressed the on-off button, like me
read this varia-vision-connect-disconnect-loop-after-6x-sapphire-update
Hey guys, if you haven't tried this already completely remove the Vision sensor from your watch. Power cycle the watch and then pair your Varia Vision again. Is everyone having this Connect/Disconnect issue in both Cycling and Running activities? If you're still experiencing the issue please send me a private message so I can get you added to a case.
I finally got it to the main screen but it rebooted again. I wasn't even touching it. I don't think I'm touching power cause power is on top .
