Can someone please confirm if the 945 should be recording cadence / SPM without any additional hardware such as running pod or HRM-Run? My first run yesterday with the 945 shows zero for the entire 2 miles of running.
I'm not aware of any way to disable it so I would expect it to be working. If you've added any watch faces, data fields or CIQ apps then you might want to try removing/disabling them. If you haven't added any, try a hard reset - press and hold the top left button until it powers off then restart. If that has not worked, contact Garmin Support. Up to you whether or not you Factory Reset before you contact support, but it's quite likely they will ask you to do so.
BTW - this was a run on my wife's 945 - connect.garmin.com/.../3661755492
