How much coursepoint
The Garmin 935 could only handle 50 coursepoints, how much coursepoint can a 945 handle?
  • I did a quick search on the 945 manual PDF and the phrase "course points" didn't produce any results. I also scanned the Navigation section of the manual and didn't see any mention of it but I wasn't reading it closely.
    Here's a link to the English PDF manual. If you're native language is different check the country Garmin site to see if the have the manual up yet.
    http://static.garmin.com/pumac/Forerunner_945M_OM_EN-US.pdf
  • It's never mentioned in any manual or review, but there are huge differences;
    Forerunner 935 50points
    Edge 520 250points
    Edge 520 plus 200points
    Edge 530?
    Forerunner 945?
    For me this is a important feature, but it's only mentioned by the device when I am starting a fit course file with to much tbt info.
  • Nobody from Garmin can answer this question?
    I tried....
    1. Previous week I saw a message on my FR935 telling me the max was 50
    2. Do not rember which course file it was :rolleyes:
    3. Dumped the FR945 device.fit file in csv format perhaps you know the file type to look for
    have fun searching....my guess was also 50....
    FR945 device.fit
    vvvvvvv
    Definition,3,capabilities,workouts_supported,1,,connectivity_supported,1,,unknown,1,,unknown,1,,sports,1,,unknown,1,,unknown,1
    Data,3,capabilities,workouts_supported,"1923",,connectivity_supported,"555735034",,unknown,"3",,unknown,"7",,sports,"39",,unknown,"1",,unknown,"1"
    Definition,4,file_capabilities,directory,16,,max_count,1,,type,1,,flags,1
    Data,4,file_capabilities,max_count,"1",,type,"1",,flags,"2"
    Data,4,file_capabilities,directory,"Settings",,max_count,"1",,type,"2",,flags,"6"
    Data,4,file_capabilities,directory,"Sports",,max_count,"6",,type,"3",,flags,"6"
    Data,4,file_capabilities,directory,"Activity",,max_count,"200",,type,"4",,flags,"10"
    Data,4,file_capabilities,directory,"Workouts",,max_count,"25",,type,"5",,flags,"14"
    Data,4,file_capabilities,directory,"Courses",,max_count,"100",,type,"6",,flags,"14"
    Data,4,file_capabilities,directory,"Schedule",,max_count,"1",,type,"7",,flags,"6"
    Data,4,file_capabilities,directory,"Location",,max_count,"1",,type,"8",,flags,"6"
    Data,4,file_capabilities,directory,"Totals",,max_count,"1",,type,"10",,flags,"2"
    Data,4,file_capabilities,directory,"Goals",,max_count,"1",,type,"11",,flags,"6"
    Data,4,file_capabilities,directory,"Records",,max_count,"1",,type,"29",,flags,"6"
    Data,4,file_capabilities,directory,"Segments",,max_count,"200",,type,"34",,flags,"14"
    Data,4,file_capabilities,directory,"Seg_List",,max_count,"1",,type,"35",,flags,"14"
    Data,4,file_capabilities,directory,"MltSport",,max_count,"10",,type,"33",,flags,"6"
    Data,4,file_capabilities,directory,"Monitor",,max_count,"75",,type,"32",,flags,"10"
    Data,4,file_capabilities,directory,"HMD",,max_count,"1",,type,"40",,flags,"6"
    Data,4,file_capabilities,directory,"SCORCRDS",,max_count,"10",,type,"38",,flags,"10"
    Data,4,file_capabilities,directory,"Adjstmts",,max_count,"5",,type,"39",,flags,"14"
    Data,4,file_capabilities,directory,"Metrics",,max_count,"100",,type,"44",,flags,"14"
    Data,4,file_capabilities,directory,"ChngLog",,max_count,"1",,type,"41",,flags,"6"
    Data,4,file_capabilities,directory,"Sleep",,max_count,"20",,type,"49",,flags,"10"
    Data,4,file_capabilities,directory,"SUMMARY",,max_count,"100",,type,"20",,flags,"12"
    Definition,5,mesg_capabilities,mesg_num,1,,count,1,,file,1,,count_type,1
    Data,5,mesg_capabilities,mesg_num,"3",,num_per_file,"1",,file,"2",,count_type,"0"
    Data,5,mesg_capabilities,mesg_num,"4",,num_per_file,"1",,file,"2",,count_type,"0"
    Data,5,mesg_capabilities,mesg_num,"6",,num_per_file,"1",,file,"2",,count_type,"0"
    Data,5,mesg_capabilities,mesg_num,"127",,num_per_file,"1",,file,"2",,count_type,"0"
    Data,5,mesg_capabilities,mesg_num,"147",,num_per_file,"20",,file,"2",,count_type,"0"
    Data,5,mesg_capabilities,mesg_num,"8",,num_per_file,"6",,file,"3",,count_type,"0"
    Data,5,mesg_capabilities,mesg_num,"53",,num_per_file,"11",,file,"3",,count_type,"0"
    Data,5,mesg_capabilities,mesg_num,"9",,num_per_file,"8",,file,"3",,count_type,"0"
    Data,5,mesg_capabilities,mesg_num,"14",,num_per_file,"7",,file,"2",,count_type,"0"
    Data,5,mesg_capabilities,mesg_num,"14",,num_per_file,"40",,file,"3",,count_type,"0"
    Data,5,mesg_capabilities,mesg_num,"16",,num_per_file,"14",,file,"3",,count_type,"0"
    Data,5,mesg_capabilities,mesg_num,"74",,num_per_file,"1",,file,"3",,count_type,"0"
    Data,5,mesg_capabilities,mesg_num,"17",,num_per_file,"5",,file,"3",,count_type,"0"
    Data,5,mesg_capabilities,mesg_num,"152",,num_per_file,"1",,file,"3",,count_type,"0"
    Data,5,mesg_capabilities,mesg_num,"144",,num_per_file,"5",,file,"33",,count_type,"0"
    Data,5,mesg_capabilities,mesg_num,"19",,max_per_file_type,"200",,file,"6",,count_type,"2"
    Data,5,mesg_capabilities,mesg_num,"20",,max_per_file_type,"14000",,file,"6",,count_type,"2"
    Data,5,mesg_capabilities,mesg_num,"32",,max_per_file_type,"100",,file,"6",,count_type,"2"
    Data,5,mesg_capabilities,mesg_num,"149",,num_per_file,"3",,file,"34",,count_type,"0"
    Data,5,mesg_capabilities,mesg_num,"150",,max_per_file,"10000",,file,"34",,count_type,"1"
    Data,5,mesg_capabilities,mesg_num,"142",,max_per_file,"1",,file,"34",,count_type,"1"
    Data,5,mesg_capabilities,mesg_num,"151",,max_per_file,"100",,file,"35",,count_type,"1"
    Data,5,mesg_capabilities,mesg_num,"158",,max_per_file,"5",,file,"5",,count_type,"1"
    Data,5,mesg_capabilities,mesg_num,"27",,max_per_file,"50",,file,"5",,count_type,"1"
    Data,5,mesg_capabilities,mesg_num,"28",,max_per_file,"200",,file,"7",,count_type,"1"
    Data,5,mesg_capabilities,mesg_num,"137",,max_per_file,"5",,file,"7",,count_type,"1"
    Data,5,mesg_capabilities,mesg_num,"29",,max_per_file,"100",,file,"8",,count_type,"1"
    Data,5,mesg_capabilities,mesg_num,"114",,num_per_file,"10",,file,"29",,count_type,"0"
    Data,5,mesg_capabilities,mesg_num,"200",,num_per_file,"8",,file,"40",,count_type,"0"
    Data,5,mesg_capabilities,mesg_num,"201",,num_per_file,"25",,file,"40",,count_type,"0"
    Data,5,mesg_capabilities,mesg_num,"202",,num_per_file,"60",,file,"40",,count_type,"0"
    Definition,6,field_capabilities,mesg_num,1,,count,1,,file,1,,field_num,1
    Data,6,field_capabilities,mesg_num,"14",,count,"4",,file,"3",,field_num,"5"
    Data,6,field_capabilities,mesg_num,"14",,count,"8",,file,"3",,field_num,"7"
    Data,6,field_capabilities,mesg_num,"20",,count,"1",,file,"4",,field_num,"0"
    Data,6,field_capabilities,mesg_num,"20",,count,"1",,file,"4",,field_num,"1"
    FR935 device.fit
    vvvvvvv
    Data,3,capabilities,workouts_supported,"1923",,connectivity_supported,"555735034",,unknown,"3",,unknown,"15",,sports,"39",,unknown,"1",,unknown,"1"
    Data,4,file_capabilities,directory,"Courses",,max_count,"30",,type,"6",,flags,"14"
    Data,4,file_capabilities,directory,"Clubs",,max_count,"1",,type,"37",,flags,"14"
    Data,4,file_capabilities,directory,"Metrics",,max_count,"50",,type,"44",,flags,"14"
    Data,5,mesg_capabilities,mesg_num,"16",,num_per_file,"10",,file,"3",,count_type,"0"
    Data,6,field_capabilities,mesg_num,"14",,count,"4",,file,"3",,field_num,"7"
    EDGE820 device.fit
    vvvvvvvvvv
    Data,3,capabilities,connectivity_supported,"563816441",,unknown,"3",,unknown,"31",,sports,"4",,unknown,"1",,unknown,"1"
    Data,4,file_capabilities,directory,"Sports",,max_count,"2",,type,"3",,flags,"6"
    Data,4,file_capabilities,directory,"Activities",,max_count,"200",,type,"4",,flags,"10"
    Data,4,file_capabilities,directory,"Workouts",,max_count,"200",,type,"5",,flags,"14"
    Data,4,file_capabilities,directory,"Schedules",,max_count,"1",,type,"7",,flags,"6"
    Data,4,file_capabilities,directory,"Locations",,max_count,"1",,type,"8",,flags,"6"
    Data,4,file_capabilities,directory,"Weight",,max_count,"1",,type,"9",,flags,"2"
    Data,4,file_capabilities,directory,"Segments",,max_count,"100",,type,"34",,flags,"14"
    Data,4,file_capabilities,directory,"Segment_List",,max_count,"1",,type,"35",,flags,"14"
    Data,4,file_capabilities,directory,"Metrics",,max_count,"25",,type,"44",,flags,"14"
    Data,5,mesg_capabilities,mesg_num,"6",,num_per_file,"10",,file,"2",,count_type,"0"
    Data,5,mesg_capabilities,mesg_num,"139",,num_per_file,"1",,file,"2",,count_type,"0"
    Data,5,mesg_capabilities,mesg_num,"203",,num_per_file,"1",,file,"2",,count_type,"0"
    Data,5,mesg_capabilities,mesg_num,"9",,num_per_file,"10",,file,"3",,count_type,"0"
    Data,5,mesg_capabilities,mesg_num,"10",,num_per_file,"22",,file,"3",,count_type,"0"
    Data,5,mesg_capabilities,mesg_num,"14",,num_per_file,"16",,file,"3",,count_type,"0"
    Data,5,mesg_capabilities,mesg_num,"16",,num_per_file,"3",,file,"3",,count_type,"0"
    Data,5,mesg_capabilities,mesg_num,"17",,num_per_file,"4",,file,"3",,count_type,"0"
    Data,5,mesg_capabilities,mesg_num,"70",,num_per_file,"3",,file,"3",,count_type,"0"
    Data,5,mesg_capabilities,mesg_num,"71",,num_per_file,"11",,file,"3",,count_type,"0"
    Data,5,mesg_capabilities,mesg_num,"215",,num_per_file,"1",,file,"2",,count_type,"0"
    Data,5,mesg_capabilities,mesg_num,"19",,max_per_file,"1000",,file,"6",,count_type,"1"
    Data,5,mesg_capabilities,mesg_num,"20",,max_per_file,"10000",,file,"6",,count_type,"1"
    Data,5,mesg_capabilities,mesg_num,"23",,num_per_file,"20",,file,"9",,count_type,"0"
    Data,5,mesg_capabilities,mesg_num,"32",,max_per_file,"200",,file,"6",,count_type,"1"
    Data,5,mesg_capabilities,mesg_num,"149",,num_per_file,"6",,file,"34",,count_type,"0"
    Data,5,mesg_capabilities,mesg_num,"137",,max_per_file,"10",,file,"7",,count_type,"1"
    Data,5,mesg_capabilities,mesg_num,"29",,max_per_file,"200",,file,"8",,count_type,"1"
    Data,5,mesg_capabilities,mesg_num,"30",,num_per_file,"20",,file,"9",,count_type,"0"
    Data,6,field_capabilities,mesg_num,"14",,count,"10",,file,"3",,field_num,"7"
    Data,6,field_capabilities,mesg_num,"14",,count,"10",,file,"3",,field_num,"5"
    FR920XT device.fit
    vvvvvvvvv
    Definition,3,capabilities,workouts_supported,1,,connectivity_supported,1,,sports,1,,unknown,1,,unknown,1
    Data,3,capabilities,workouts_supported,"1923",,connectivity_supported,"536872570",,sports,"39",,unknown,"1",,unknown,"1"
    Data,4,file_capabilities,directory,"Activity",,max_count,"75",,type,"4",,flags,"10"
    Data,4,file_capabilities,directory,"MltSport",,max_count,"5",,type,"33",,flags,"6"
    Data,4,file_capabilities,directory,"Monitor",,max_count,"20",,type,"32",,flags,"10"
    Data,5,mesg_capabilities,mesg_num,"5",,num_per_file,"1",,file,"2",,count_type,"0"
    Data,5,mesg_capabilities,mesg_num,"14",,num_per_file,"13",,file,"3",,count_type,"0"
    Data,5,mesg_capabilities,mesg_num,"16",,num_per_file,"8",,file,"3",,count_type,"0"
    Fenix5 device.fit
    vvvvvv
    Data,4,file_capabilities,directory,"Metrics",,max_count,"1",,type,"44",,flags,"14"
  • So, according to those files I guess it's still 50... You have to look at the line with 'mesg_num,"32"'
    So for the 935, F5 and 945 it's max_count=100 and count_type=2 which I guess means 100/2 = 50 points
    For the edge820 it's 200/1 = 200?
    Meh, wondering if hacking the fit file might work ;)
    *Edit*
    So I can change the coursepoint value to 200 for example, and fix the CRC sum of the device.fit but not sure if that would work...
    Anyone have a course file containing over 50 coursepoints I can test?
