Somehow my treadmill distance is now completely off on my watch; without the HRM strap its around 30-40% and with the strap its roughly 20-25% - is there a way to get the treadmill calibration prompts to come up again?
Thanks!
Thanks!
I thought when you stop a treadmill activity at the end (before saving) the menu that includes "Save" and "Discard" etc... had a Calibrate option you could use (after the initial automated prompt process was done)?
Yes, that used to be the case. However, today (on SW 14:50) there were no option for that.
Yesterday I ran for the first time on a curved treadmill with this watch. In the end it asked me to calibrate the distance.
Did you run with or without a strap? HRM pro og pro +.. - I can see the option to calibrate too, but only if I wear a strap
..right! I had the HRM Pro on. (I went to a spinning class and then ran on the treadmill - wasn't even thinking that I had the strap on from the beginning.)
