Can't control Tacx Trainer
Short Version: Bought a Tacx Neo 2T - Watch fails to control Power, Resistance or Grade - in workout mode and manual mode. Does anyone has the same problem or is my watch broken?
Tried todays suggested workout, and it started just fine. Trainer set to 155W target and it stayed perfectly at that level. But when the 500W Intervals started, trainer just stayed at 155W. I could do nothing about it since its erg mode, even when shifting gears trainer holds exactly 155W.
Also tried to set power manually, watch shows trainer power I choose, but trainer does not change power. Same for Power, Resistance and Grade.
Tested with following workout and some manual activities. Trainer reacts to absolutely nothing i change on the watch.
