Navigation settings (errors)
Appeared with 6.04, continue with 7.07:
- Settings -> Navigation -> Datascreens.
Beginning with everything Off - works correctly, only activity data screens are visible (and ClimbPro if checked)
Turn UpAhead On, others are Off. - appears Compass page instead of UpAhead page
Turn Elevation plot On, others are Off - appears Screen 1 instead of Elevation plot
this happens to all - screens are moved by ONE.
In this constallation I can´t see UpAhead screen. I can see others, but only with workaround: setting trailing screen On.
(But some of us can, so what should I do to work it right?: forums.garmin.com/.../up-ahead-screen-not-displayed
If I select to appear Screen 1 (status is On), it is not reflected in main Navigation Data Screens menu). If I select Screen 2, Screen 1 will be on. So, here is the same problem - in main  "Data screens", the status for Screen 1-4 is moved by ONE again.
Thread moved on Garmin request.
