Hey,
Do you think any future update will solve the bad battery life of this watch when LTE is enabled?
I never even got close to half of the promised LTE battery life.
Garmin gave me the offer to get a replacement watch but I expect to get exactly the same basically useless watch.
Some background, I did a run (I expected it to take about 12 hours it took me 13h in the end but the watch just died after like 7 hours without any warning.
As I wanted to check how much battery would be left after this run I disabled everything except LTE to get good values But instead of measuring how much battery would be left I just ended up with a very frustrating run and nothing to show for it on Strava.
I did some research before and everyone told me a 945 should even last a slow Ironman without any issues which is why I wanted the watch.
After I found the LTE version of the watch I did some math:
GPS Mode without Music Battery Life: 35h
GPS Mode with Music Battery Life: 12h (lets say 40% of the time without music)
GPS Mode with Music and LTE2 LiveTrack Battery Life: 7h (which is like 60% of with music)
As I didn't use any music and disabled literally everything I expected a little more than 60% of 35h (and Garmin is usually very conservative with their numbers)
Which amounts to about 21 hours and that sounded fine for me.
The Garmin support never gave me an answer if they were even working on fixing this.
Have you as a community ever gotten any better answer from the Garmin support regarding this issue?
(I know Garmin recently added a line "GPS Mode and LTE2 LiveTrack Battery Life" but that is still less than what I got and was definitely not there when I bought the watch)
