Hey guys,
The other day I did a run up Twin Peaks, which I was rather proud of. I had my watch in Run mode, with Livetrack enabled, although I doubt it ever got sufficient service to begin. The GPS however locked on great, and I had seemingly normal distance/pace/etc info during the run. After finishing though, the activity showed all normal data except position and showed no map. I thought it was odd, and what's more odd the watch didn't on its own like usual. I powered it down, at which point it installed an update. Then on startup, the watch prompted me for another update, after which I got a quick "Livetrack ended" and at least 2 other messages that flashed too quick to catch. I've run since, and activities before and after this event work normally.
In the files, I noticed that the "Splits" CSV has my 4-6 miles as having 37+ hours each...which is obviously not correct. I'm sure this is significant to someone who knows GPS, TCX files better than I. Anyhow any help would be appreciated if I can somehow fix the files to make a map for my run! Would be happy to post the relevant files for troubleshooting.
Thanks,
Trevor
