Forerunner 945 LTE - Beta Software version 5.07 Now Available!
Download
Notes:
  • Upgrading to this software will prevent downgrading to previously released software.
  • For any issues that you encounter please fill out the form included in the download and attach it to an email to [email protected]. Please note that you may not get a response to the email unless we need more information on the issue you report.
  • Although this software is believed to be reliable, it has not yet been released for production and should be used at your own risk.
Changes made from version 4.16 to 5.07:
  • Resolved issue where strength personal records weren’t sent to device via Connect.
  • Improvements to prevent LiveTrack start failures.
  • Resolved issue displaying event time in the Calendar glance.
  • Added support for Connect IQ system 5.
  • Added ability to enable/disable display of inReach data page in timer loop.
  • Resolved inconsistency in Activity Summary when viewed from Last Sport widget vs. history.
  • Resolved issue with strength activities where weights set by percent of benchmark in Connect were not being used.
  • Added support for assigning a Hot Key to trigger a Lap.
  • Added additional Ultra Run settings.
  • Modified the software update process to allow the user to defer the installation. This replaces the automatic install during the user's sleep window.
  • Added new Pickleball, Padel, Tennis, and Snowshoe activities.
  • Added ability to abort when cycling or running a segment.
  • Improvements to altimeter calibration.
  • Improvements to Assistance countdown page.
  • Added pace alert for Rowing and SUP activities.
  • Resolved issue using custom cross-country ski workouts defined in Connect.
  • Improve workout set editor by remembering previously entered weight.
  • Other minor bug fixes and improvements.
Installation Instructions
  1. Connect your Forerunner 945 LTE to your computer using the USB cable.
  2. Download and unzip Forerunner945LTE_407Beta.zip. Place the GUPDATE.GCD file in the Garmin folder of your device's internal storage drive.
  3. Disconnect your device from the computer, approve the update on the watch, and wait for the update to finish.
  • thanks for the detailed report . i'm glad to see they finally did something to make the alarm list a bit more sensical.
    i'm also glad that you haven't seen any major issues (although the lap swim one is worrisome if it recurs). still on fence whether i take the plunge. as i said, small complaints aside, my watch is functioning reasonable well, so not willing to rock the boat. if i knew they had implemented the properly outfitted battery saver, i would have already jumped to the beta. body battery isn't giving me a huge amount of urgency to be a beta tester. thanks for being my guinea pig :)
  • Just a super-minor clarification.  The alarm list is still sorted by order of creation (not based on alarm time), but the shortcut / "controls" menu (press and hold power) shows an active alarm vs the first in the list.
    I'd still like to see the list get sorted in order of time with the "next occurring" on top Slight smile
    edit to correct…. Misspoke on the above comment in that I had not properly tested creation of new alarms.  I just added a new one today and it DID correctly insert it into my list chronologically (I had a 4:50 alarm and a bunch after 5:30.  When I added a 5:10 it showed after the 4:50 and before the later ones).
    Now, if the “time now” was 5:05 I’d like the first in the list to show 5:10 vs 4:50 (next possible occurring) but this is still an appreciated change that I apologize for mistakenly claiming it was still wrong.
  • oh bummer. thanks for the clarification. i too would like to see the next recurring on the top of the Alarm list.
  • Swim repeats are still broke crash/loop/instant workout end.
    Battery life has been the same the same for me, luckily perfectly fine..  86% before install, 4 days later 72%.   Including 1 swim 'workout' of use.
