Downgrading from 4.07 to latest available firmware on Garmin Express
Hello,
Tried 4.07 beta hoping it would solve some issues with my Garmin 945 LTE. While it solved one issue... it created and even worse one. So since I have to pick the firmware version that is "less BAD" (both are bad compare to my previous Garmin 945 "not LTE" which was working perfectly and I wish I kept !!!), can someone help getting my watch back to "standard mode" (not beta) so that I'm getting the firmware updates as usual on Garmin express ?
Thanks a lot !
    Next time you update you should read the release notes.
    From Beta 4.07 version release notes:
    Notes:
    • Upgrading to this software will prevent downgrading to previously released software.
    • For any issues that you encounter please fill out the form included in the download and attach it to an email to [email protected]. Please note that you may not get a response to the email unless we need more information on the issue you report.
    • Although this software is believed to be reliable, it has not yet been released for production and should be used at your own risk.
  • as per ScaniaKid85, i avoided trying the demo because of the warning. yet, i thought there was a way to do the downgrade (at least previously on my 935) but it wiped out everything and one lost all their settings, etc. but i may be wrong. you may want to search this forum site for clues to see if it is even possible or not.
