Missing Battery Saver option during sleep?
anyone else find somewhere else to enable this? i do not see this Sleep Time option under Battery Savor (only status and update)
i think this would be a nice way to get back some of the inefficiencies in the watch's battery consumption.
Customizing the Battery Saver Feature
The battery saver feature allows you to quickly adjust system settings to extend battery life in watch mode. You can turn on the battery saver feature from the controls menu (Viewing the Controls Menu, page 56). 1Hold .
  1. 2  Select Settings > Power Manager > Battery Saver.
  2. 3  Select Status to turn on the battery saver feature.
  3. 4  Select Edit, and select an option:
    • Select Watch Face to enable a low-power watch face that updates once per minute.
    • Select Music to disable listening to music from your watch.
    • Select Phone to disconnect your paired phone.
    • Select Wi-Fi to disconnect from a Wi‐Fi network.
    • Select Activity Tracking to turn off all-day activity tracking, including steps, floors climbed, intensity minutes, sleep tracking, and Move IQ events.
    • Select Wrist Heart Rate to turn off the wrist heart rate monitor.
    • Select Backlight to disable the automatic backlight.
      The watch displays the hours of battery life gained with each setting change.
  4. 5  Select Sleep Time to enable the battery saver feature during your normal sleep hours.
    TIP: You can set your normal sleep hours in the user settings on your Garmin Connect account.
  5. 6  Select Low Battery Alert to receive an alert when the battery is low
