- Hi all. Lets Add all the user experience with the 4.07 Beta here. Here's mine so far:
New stuff:
- Body battery 2.0 - looks great, works great
- Activity called Health Snapshot. I hope I will be able to see HRV in Intervals.icu (or TrainingPeaks.com). Previously this type of data had to be synced manually.
Fixed:
- SUP, Indoor rowing - stroke count works - FIXED
- Compass calibration - still fails couple of times before it says successful but at least it is possible to calibrate. Previously watch had to be restarted in order to be able to calibrate the compass - PARTIAL FIX
- Heart Rate Gauge Data field in 4 data field layout is now tiny and is not quickly readable - Heart Rate Gauge Data field in 4 data field layout is now very small!!! Used to be big? Now you have to switch to a three data field layout to get the bigger hr number? There is no way I can see this while I am running! Why did this change?! - Forerunner 945 LTE - Running/Multisport - Garmin Forums - FIXED
- Battery life during normal activities like "Bike" with LTE and LiveTrack on. It is consuming right now roughly 1% per 7 minutes which should give around 11,5 hours - manual says 10 hours
Fishy:
- HealthSnapshot is not visible on Garmin Connect app nor web. Probably because this feature is beta on 945 LTE
The bad:
- New HealthSnapshot activity eats through battery like crazy. 1-2% per one measurement
- HealthSnapshot activity has back-light on during the whole 2 minutes measurement. Makes no sense
- HealthSnapshot activity when paired with chest strap won't measure HRV. Not only it doesn't make sense but also chest strap should be preferable during measurement. Watch sensor is not good enough for reliable HRV measurements
- Battery on open water with LTE on devoured 25% in one hour
- New/Changed Strength watch face is better but after a finished set editing values works worse than the previous version. In the previous version the default value for weight was the previous weight. Now it is 0. Should be previous weight. Otherwise it is a better functioning and better looking face
- Scrolling through the widgets is laggy, especially when scrolling down from body battery and up from notifications
- LiveTrack with LTE turned on, is not paused when activity goes into Resume Later mode. LiveTrack should be paused or stopped to save the battery which is the purpose of Resume Later mode.
