I am trying to upload a PacePro Strategy from either the website or the Connect app and either one says that the Garmin 945 LTE is not supported.
When will support be added?
That’s interesting. According to the spec sheet it should, but mine also shows as incompatible in Connect.
It's supposed to: https://support.garmin.com/en-US/?faq=q5uf6eUeBH1jJn0OqXrz26
Now that the 55 has it, it should be on every current Forerunner.
Just broken for the moment, I guess.
When you start a run activity and then go to the menu there is a PacePro Plans item under training. I haven’t tried it, that seems like they are supposed to be supported.
By the way, Garmin Connect used to always tell me run workouts were not supported when I selected to upload to my 935. But, they always loaded and ran on the watch.
The problem is that you have to use the Connect app to load the PacePro plan onto the watch. Currently when you try to do that the app shows the 945 LTE as unsupported.
Today it showed up as "supported" in the PacePro Strategy section of the Garmin Connect app! I guess we can say it's solved! Thanks everyone.
There was not an update to the app, so I am assuming there was a server-side switch toggled to enable it for this watch.
Yep. Shows as supported for me now too.
