Strange line on the edge of a forerunner 745
Hey, I have bought 2 handed forerunner 745 a few months ago and a strange line that seems like an air between the screen and the screen saver had started to appear on the side of the watch. Ive tried to remove this but couldnt (maybe there is no screen saver and the problem is on the screen).
video: https://streamable.com/x2i1s6
Top Replies
  • Hello ,
    We're sorry to hear this. I would suggest reaching out to the support team directly in your region. After you open the link type in your product. Then search for screen. If you scroll to…
All Replies
  • Hello ,
    We're sorry to hear this. I would suggest reaching out to the support team directly in your region. After you open the link type in your product. Then search for screen. If you scroll to the bottom of the page there are contact option. Product Support
  • A day before I opened this subject I went to official Garmin store (not lab) and they said they dont know whats the problem
  • The aame thing has happened to my 745.  I have seen 945 owners complaining of a similar problem which they attributed to a manufacturing defect that caused the bonding under the screen to fail.  I have reached out to Garmin Support to see if there are any fixes available.  Not impressed that a very expensive 3 year old watch that hasn’t been abused should fail in this way.
  • did you find any solution?
  • No solution suggested unfortunately, although Support have offered to swap it for a new discounted 265.
    Although I think the Support offer is fair for an out of warranty product, I'm not sure if I want another expensive Garmin if they have built in obsolescence like this after 3 years. I might just keep the 745 and hope this is mostly a cosmetic issue I can ignore, and then try a different manufacturer when it finally dies.
    If you check the 945 forum you will see lots ofsimilar problems reported.  One brave owner even provided instructions on how to replace your entire screen, which I would definitely not trust myself to do
  • From what I understand, there isn’t much that can be done. A DIY fix wouldn't even come close to the water-resistance levels of a new watch.
    The main issue is that by doing nothing, the compromised seal could eventually allow water to reach the internal components, which would completely destroy the watch. This is a real problem for me since I swim from time to time.
    Anyway, this is a very big disappointment from Garmin. I will also look for a different manufacturer.
