Manual correction of sleep times repeatedly being reverted by FR 745
Hello all,
I am having continued issues with editing the sleep times recorded by my Forerunner 745. Since the recorded sleep times are usually incorrect (this is not my complaint here!), I usually start my day by correcting the sleep times manually in the Garmin Connect App.
However, I keep having the problem that my manual changes are reapetedly being undone once Garming Connect and FR 745 synchronize again. This means that instead of Garmin Connect sending the corrected sleep time to the FR 745, Garmin Connect reverts my manually corrected sleep times back to the original incorrect start and end times from the FR 745. Only when changing the times again later during the day (let's say at least 1 hour after actually getting up), the FR 745 will eventually accept the times set in Garmin Connect instead of vice versa.
This problem is also independent of the number of times I change the sleep times. This morning I corrected the times at least 5-6 times before the FR 745 would finally accept the changes instead of overriding them once again. I sincerely hope that this behavior is not intended, since obviously manual corrections by a user should not just be superceded by what the wearable believes to be correct.
Is anyone experiencing the same issue and knows how to fix or circumvent this?
Thanks in advance!
