BETA - Forerunner 745 4.04
Download
Notes:
  • For any issues that you encounter please fill out the form included in the download and attach it to an email to [email protected]. Please note that you may not get a response to the email unless we need more information on the issue you report.
  • Although this software is believed to be reliable, it has not yet been released for production and should be used at your own risk.
Changes made from version 3.40 to 4.04:
  • Improve the software update process for external accessories. Installation prompts will now appear after an activity to avoid interrupting activity start.
  • Improvements to heart rate broadcast.
  • Add more smartphone app logos for smart notifications.
  • Block music controls and disconnect headphones in airplane mode.
  • Fix a rare issue that could cause heart rate data to appear flat in Garmin Connect.
  • Fix an issue that could prevent LiveTrack from starting when Auto Start is enabled.
  • Fix a graphical issue with workout alerts when the background color is set to black.
  • Fix an issue sometimes causing distance remaining to not display the hundredths digit.
  • Add XC Ski Power
  • Add Nutrition and Hydration alerts
  • Added alerts for ClimbPro to notify of upcoming climbs
  • Added descents to ClimbPro when enabled for non-cycling activities.
  • Other minor improvements and bug fixes.
Installation Instructions
  1. Connect your Forerunner 745 to your computer using the USB cable.
  2. Download and unzip Forerunner745_404Beta.zip. Place the GUPDATE.GCD file in the \GARMIN folder of your device's internal storage drive.
  3. Disconnect your device from the computer, approve the update on the watch, and wait for the update to finish.
  4. If you would like to revert to the last public release software, place the GUPDATE-340.GCD file in the \GARMIN folder. Rename GUPDATE-340.GCD to GUPDATE.GCD before disconnecting your device. NOTE: If you revert to an older version of software, all of your settings will be reset to defaults.
