Hello everyone!!
Sometimes the entire menu on my watch disappears completely, and I have to set it up again. Happens to you?
Thank you.
In my case, while I didn't do much research, it seems to be random. The problem is that the menu empties and the device cannot be turned off. Then I go to Garmin Connect, in the menu area I restart, I synchronize and it reappears by default. Then to reconfigure it to my need. Horrible. Regards
Yesterday I added all the menu toggles because they disappeared. Turned off the watch. Today I went for a run and the menu was there. Synced the run via WiFi and then synced via Bluetooth to the phone (iOS) When I should turn off the watch the menu was gone. To turn the watch off I have to add the turn off menu button...
I suspect that it is a iOS Garmin Connect Mobile issue. A couple of years ago the same problem happened to the widgets...
