Intensity minutes not recorded for Zwift rides
First off I have never been able to wear my Garmin watches when using Zwift. I have found that the bluetooth signal from the watch can interfere with the signals from my trainer and HR monitor, causing intermittent drop outs and interference. That has been the case with both my old Forerunner 45 and my newer Forerunner 55. I have also tried recording an indoor bike ride on my watch while riding Zwift, but then the Zwift ride does not show up on Garmin Connect. I've learned to deal with that problem by plugging in my watch to charge, on the opposite side of the house, while I do a Zwift ride. Then the Zwift ride and all of its data gets loaded into Garmin Connect and there is no problem with signal interference. I don't need my watch when I have a computer screen feeding me constant performance data anyway, so it's really not a problem.
The one nuisance factor about this is that the effort does not get counted in my Intensity Minutes. I guess only workouts recorded by the watch count towards IMs? Is there any way to include my significant (at this time of year) indoor cycling efforts in my overall intensity minutes total for the week?
  • The only way I can get Intensity Minutes while zwifting is to record the activity on the watch, I also record zwift rides on my Edge 530 at the same time, If I use just the Edge I don't get any Intensity Minutes either, seems they have to be recorded on the watch, I then have three activities on garmin connect, I delete the zwift & the watch ones and just keep the Edge 530 activity, Haven't have any interference problems with BT but I mostly use ant+ for rides, BT for the the treadmill
