Forerunner 265 interface lag
Hi all, For the past 2 days, my 265 has had really bad lag (of a few seconds) when opening the glances menu. It is better when glances are opened but also see the problem when I go to start an activity or move through or select settings.
Have tried a soft and hard reset.
Running 24.12
  • My 965 is OK. Try a software reinstall if you haven't already and see if that helps.
    Settings, About press light button 8 times, select reinstall software
  • Hi. Thanks for taking the time to respond. I have just tried that.  Issue still occurs unfortunately.
  • Hello, are you able to attach a video link of this concern?
  • Hi. Sure. See attached. Same thing happens when I go into different screen or if I pause and resume an activity. Thanks
  • Perfect, thank you so much! Do I have permission to email you?
  • Hi are you able to contact me via email regarding my issue? Thanks
