When I swim breaststroke style, the 265 doesn't measure anything but time and heartbeat. It doesn't count laps nor calculate distance. Any suggestions?
If you go to Garmin Connect website
Select the activity
There is a gear icon in the right top, select export file. It will do a .zip file to your downloads folder.
If you the go to this tool and import it , you can see details and also edit it
https://www.swimmingwatchtools.com/
I use it if my strokes are wrong or if some laps get split due to an anomaly and then fix an re-upload to Connect (after deleting the original activity)
So when swimming today I tried to see how I swim, My hands remain about 5 - 10 cm under the water surface , apart from if I grab the pool side on some turns.
If (FR965) records it as breaststroke and generally my laps are ok, unless I have an issue mid lap, such a bump another swimmer when the pool is busy.
