Factory reset help
I know i'm missing something in the instructions...
I powered the F265s off
I powered it on holding power (upper let) and back (bottom right)
Instructions said to hold them until i hear a beep.  Then release the power.  But I don't hear a beep and the screen goes dark.
I've done this 6+ times.
What am i doing wrong?
Thanks and sorry to be so slow
Len
  • I did this with my 965.
    Hold in power button (Top Left) ONLY.    (not as you say I powered it on holding power (upper let) and back (bottom right))
    Then release it for a moment , holding in the Right Top and Bottom buttons
    After first beep, release top right
    After second beep release bottom right
    Then you should get a cog wheel and restart,
    See also this support note (under the Forerunner piece)
    https://support.garmin.com/en-US/?faq=IWfNuaG0jn6d6oQ4HCVz29
    Hope that helps.
    I had to redo all my settings etc
    Also remove your device from GC app and Phone BT settings as you need to re-pair it
    have fun!
  • Worked perfectly.  Everything is working.  Just afraid to use it until i hear the OK from Garmin
    Thanks again
