Hello at all, sind the last update the swim distance for swim pool is gone unreliable. It is so sensitive now, that even smallest mistakes ending in a plus of meters. I took now all automatic stuff out, to minimise the failures, but it is very disappointing. I have to rely on this because I train often alone. by a 1000m freestyle test on a 25m pool it was over 125m! that is too much. I can live with 25m. Before the update it worked perfectly fine. As an alternative it should be possible to correct the laps in the rounds. You can see at the rounds which rounds are wrong. If I swam 1125m in one round should be possible to correct this to 1000m. its not helpfull only to correct the overall distance of the trainingsession. thank you.
