Help with Setting Vibration Alerts for Interval Workouts
Hi everyone,
I have a Forerunner 265S, and during today’s interval workout (8x10s @ 3:10 with 3-minute breaks), I found myself constantly needing to raise my wrist to check the intervals. I’d love to set up a vibration alert for interval start and end, so I can stay focused on the workout.
Could anyone guide me on which settings I need to adjust to enable this feature?
Thanks in advance!
  • Thats strange in my workouts it does that.
    Do you get lap alerts on a normal run activity with vibration , as an example?
    The only setting I see is under the main menu on the watch , System > Sound and Vibrate > and there select what you want . I only have alert vibration. ON
  • I kinda have the opposite situation. I do get 5sec vibration countdown alerts. But my Intervall sets are 30sec - 10sec. So 5sec countdowns are just very annoying.
    If I'm not completely crazy the timer was only 3sec before and just changed to 5sec a couple of weeks ago.
    So I would also be interested if someone could point to the settings for this. I would rather have no vibrations than 5sec, but I don't want to disable alerts for other activities like running. so changing the global settings is not a solution for me.
  • I had the same problem on my Forerunner 255s.
    I'm quite sure the timer was 3 sec and now it's 5 sec. I think the change was made by the software update I did at the end of December 2024.
    How can I set the alert duration ?
    Thanks!
  • I would also like to be able to either control how many vibrations there are at the end of the countdown, or at least go back to the 3 second ones before the update that made it 5 seconds. Way too long
