Workout display does not include HR
Hi all,
I’m hoping someone here can help clear something up for me. My watch has never shown heart rate during workouts specifically, though it displays HR fine during regular runs without the workout option enabled. I’ve combed through the manual and settings but can’t seem to figure out if this is a limitation or if there’s a workaround to get the HR display working during workouts while still tracking it as one.
Does anyone know if displaying HR during workouts is possible with this watch, or if there’s a way to track it the same as during a normal run but still log it as a workout?
Thanks a lot for any insights!
  • Do you start the workout from the activity type that has the many displays you are normally used to?
    If I do that I have the workout screen as the first screen(s) and then my normal screens behind that.
  • I start workouts via DOWN - week 5, suggested workout, do workout, run, start. Is this the same way you choose your workout?
    ‘…and then my normal screens behind that’ how do you change screens?
    Thanks
  • I select from calendar , or select activity and choose it from there using , or select from workouts activity generally
    I change screens by using the up and down buttons to move between the various screens
    I assume your normal screen setup is in the "run" activity , I have a number of run activities set up with different screens with different type names.
  • Awesome. It works!
    Thanks a lot
