265 wiped my music library AGAIN!
This is the 3rd time this has happened! I have Spotify v1.6.8 installed with about 5 playlists. Go to play a track and the track name displays but does not play and you can’t stop, start or change tracks. Go to the library and the playlists are there but nothing happens if you select any of them!
the standard *** answer from Garmin is to start from scratch and reload the entire library again. This works for a while before the music player locks again and the whole cycle repeats itself!
it’s clearly a major bug as it keeps repeating itself. So, Garmin when are you going to fix this????
