Projected Calories on 265S
I have a Fenix 7, that on the watch itself, shows Projected Calories for the day. My partner wants a Garmin device that has the same feature and she likes the 265S.
Does anyone with a 265, know if this feature is available on the 265? Hoping it is, as so far its the only Garmin she likes, except the Fenix 7S, but not the colours it now comes in.
Many Thanks
  • I just bought the FR265s.
    It shows active calories and resting calories at a given time, but no projection of end of day calories burned.
    Resting calories are the same each day, but you have to go into the watch and see how many active calories you’ve burned so far that day and add your resting calories to get the projection. The watch doesn’t do the math for you.
    In the standard faces, it won’t show even show active calories burned at all, only total calories (active + resting). So you have to go into the calorie widget each time to check have many active calories you’ve burned so far.
    It’s all very tedious
