Hey everyone,
I‘m not able to create a workout/training which I can use in a track-run-activity. Does anyone faces the same issue. Are there any ideas to make a created training available for track running.Thanks to all!
Hey everyone,
It sounds like you can create a running workout, but it's not visible when you select the Track Run activity. This is a known issue with several Forerunner models, including 265.
The workaround is to use the Workouts activity. First it will prompt you to select a workout (all workouts can be seen at this point), then it will ask you to select an activity (if you selected a running workout, then all running-related activities will be available, including Track Run).
