F265 with HRM-Pro Plus
Is there any need to use a HRM-Pro Plus with a F265? I have an RD-POD so I think i have all the running metrics covered. So, for lactate thresh hold, do i need a Garmin or will a CooSpo H6 work?
Thanks, Len
  • Apparently the CooSpo H6 sends R-R intervals so the watch should be able to measure HRV with accuracy for the lactate threshold.
    • Material: ABS
    • Dimensions: 60 mm * 33.8 mm * 12.2 mm
    • Weight (Sensor+Strap): 46.4g
    • Battery Life: 300h
    • Waterproof level: IP67
    • Wireless connections: Bluetooth & ANT+
    • Wireless signal strength: ANT+: 7 m, Bluetooth: 10 m
    • Mobile phone compatibility: iPhone & Android
    • Third-party App compatibility: Yes
    • Heart Rate Zones and Alert: No
    • LED indicator: No
    • Heart rate tracking: Yes
    • HRV: Yes
    • Step Tracking: No
    • Battery: CR2032
    • Memory: No
    • operating environment: 5℃ to 40℃, ≤ 95%RH
      www.coospo.com/.../h6-chest-strap-heart-rate-monitor
  • Thanks so much for your input.  Time to get off my butt and give it a try
  • did you try coospo chest strap?
    does it work for LTHR detection?
    can you please share the exact model used?
    ty
  • I did try the CooSpo H6 heart monitor.  It did pair with the 265s without any problems, and worked well.  I forgot how much more responsive the chest strap is vs the wrist.  And I tried it a couple of times before I write this.  But, LTHR didn't work.  I then bought a Garmim HRM-Pro Premium, and KTHR worked just fine.  So, it appears from an N=1 users that you need the HRM-Pro Premium to get LTHR.
  • Mmh that's strange.
    I bought the Coospo H6 in the meanwhile, this morning connected for the first time on my FR 955 (sorry not a 265) and run the Garmin LTHR test without issues.
    And finally found the LTHR value.
    So I would say that Coospo H6 works for LTHR on 955. Are you totally sure is not working on 265?
  • I just completed a lactate threshold test on my 265 with a CooSpo H6 so it seems to me that any chest strap that supports HRV will do the job. Doesn't have to be a Garmin one. The value it gave me agreed surprisingly well with TrainingPeaks and Intervals despite the (presumably) very different methodology.
  • any chest strap will do the job
    any strap that sends R-R data or supports HRV
  • That's true. Edited previous reply to clarify.
