Has anyone tried installing a QuickFit strap on a Forerunner 265?
Yes, of course, you just need 2 pieces of 22mm pins to be able to snap on.
And here is the tricky part: the el cheapo pins from amazon could be 21.5mm or 22.5 mm or anything between them (except the required 22mm), so you'd need to go your local watchmaker shop to buy a proper pair.
Thickness also matters, but you can check that there as well.
[side note: in the Golden Age of garmin, they used to sell pins, but not now, afaik]
