Everything fine after upload the activitiy to Strava , but strava didn't show the data is from 265.
However my old 945 does. anyone got this problem too?
Strava has to update its database...it hasn't yet, same happened when I got my 955, after a month or so it was sorted.
Same with Runalyze , they just added the 265 recently
Woo hoo twitter worked
Atleast for me the ticket seem to have been fixed. I see garmin forerunner 265 on strava since a week or so
I think Strava is confused as they did the 265(large) a while ago (I know as I nagged them when I got one ) and then nagged them re the 965 (as they hadn't done that at the same time either...) , so someone there probably thinks ah the 265 is done so what is the issue :-)
The 965 is much better fitting than the 955, the change in the thickness of the watch makes a huge difference, feels much smaller although the diameter is a bit larger. Sure the 265 is a bit smaller but I don't realise the difference at all. The screen on the 965 is also better as the glare is less due to the different material.
Those are two threads I did at the time.
Not sure how you find the change to AMOLED , definitely some negatives when screen goes dim during activities and one has to gesture to see clearly. But one adapts.
I really like the amoled. I used the gesture anyway for 745. also a touch wakes screen. Prior to the 955 I tried the 255. I didn't like the buttons on either found them squidgy. Would have returned the 955 but managed to scrape it.....in the house never worked out how. I'm very happy with this in comparison to the last 55 series.
