Today the watch totaly crashed by starting a run.
Hard reset does not work, i see only the triangel.
was updates.
All,
We are aware of the disruption of devices displaying a blue triangle when starting a GPS activity. Holding the power button until the unit powers off may or may not restore functionality temporarily…
All,
Thank you very much for your patience as we worked on this issue. Please see the steps from My Garmin Device Will Not Boot Past the Start Up Screen for a resolution. If you already performed the steps…
Although appreciated, it's completely absurd the only guidance we have are some other users suggesting button combinations to get these devices to power back on but not resolve this issue. Where is…
Yep, bricked Forerunner 255. I started a walk and flashing triangle. A soft reset does nothing.
I'm not using beta firmware; had an update about a week ago.
Additionally the Connect app on my phone…
When I try do the hard reset, I get the beeps and the cog/wheel to begin resetting. The bar moves about 80% of the way across and then crashes back to the blue triangle boot loop. Has this happened anyone else/is there anything else I can try? I rang Garmin support earlier and had to send them a video of this happening. No reply from them yet.
Same here!
I can start the hard reset procedure. the cogwheel shows up and the progress bar completes. After that the triangle and the bootloop starts again. I still can connect to Garmin Express by holdig the Start/Stop button, but this does not change anything.
