Bug 14.13 - Suggested Workout Not in Morning report
Been using suggested workouts for upcoming race. Did suggested workout yesterday and additional strength workout last night
Yesterday todays suggested workout was a base - 33:00. This morning nothing in the morning report and in race page no suggested workouts. Under running ->training->race->suggested workouts there is a workout.
I suspect given how I feel that my watch wants me to rest but normally I get a rest day in the system.
  • I am seeing the same behavior with 15.19, that suggested workouts are not appearing when starting an activity or in the Morning Report. The suggested workouts are visible if you drill down into the Training menu.
    This happened after I completed a Garmin Coach Training program, and the last week of that (from months ago now) is still visible in the Training tab. I wonder if that Training program was not probably closed/removed and is preventing the Suggested Workouts from appearing?
  • I am on the 16.09 Beta, I can confirm the issue is still there.
  • This bug affects also the Forerunner 955 watches as you can see here:
    https://forums.garmin.com/sports-fitness/running-multisport/f/forerunner-955-series/326027/daily-suggestion-prompts-not-working#pifragment-1279=2
    The user 9493292 proposed two solutions to this. I tried to do just the second one, which consists in joining a new Garmin Coach training plan, syncing this training plan with the watch (to do this you have to go to the training plan you have started and to select that option) and then removing it and resyncing the watch. A reboot may be needed.
    For me this method worked and, after months of not having my suggested workouts show in the morning report, they have now reappeared.
     I think you should report this bug to the developer team, because to me it seems you guys aren't aware of it.
  • I just did method no.2, the suggested workout showed up as a prompt when selecting Running activity (it didn't before due to the bug). I will report tomorrow if it also shows in the Morning Report.
    Remains to be seen if it will persist.
  • Many thanks @StreetLight! The second solution also appears to have worked for me. To summarize, the steps were:
    1. Create a new Garmin Coach training plan in the Gamin phone app and sync with the watch. Validate that workouts planned for the new plan were on now on the watch.
    2. Remove the training plan in the phone app and sync again with the watch.
    3. Restart the watch.
    After this, the suggested workouts were offered when I start a Run activity, and the suggested workout appeared in the Morning Report today.
    Hopefully others will find this workaround helpful until this bug is fixed.
  • I can confirm suggested workouts started showing in the Morning Report. I didn't need to restart the watch.
    I think there is a bug somewhere where Garmin Coach plan finishes and the watch still thinks there will be more training, thus it doesn't show Daily Suggested Workout.
