Forerunner 255S charges only to 83%
Hi.
My wife just got new forerunner 255S music. Yesterday she tried to charge it but it stopped at 83%. It is our 4th Garmin watch and it happened for the first time. Any suggestions what we can do with that?
  •  I have the same problem and have followed the same steps as you, I even bought a new charging cable AND did the full reset - this didn't fix the problem for me. I am currently also waiting for the watch the drain and holding thumbs that's the answer. I'll post my results here as well.
    UPDATE: I let the battery discharge fully and only marginally got a better battery charge, was 83% before, only getting to 86% now.
    FURTHER UPDATE: Much excitement, I finally got 100% charge!!! While my watch was charging, it was at about 83% when I did this, I did a "Power Off" from the controls screen (long hold the top left light button and select Power Off from the options). I was just curious to see if the watch continues charging when powered down. I then switched it on again and what do you know, it passed my usual 86% max and kept going, next thing I knew it was at 100%. Go figure!?!?
  • Same here except now she get it charged to 93% and it stalls out. I am going work the issue next week with Garmin support again.
  • would you please share how's the feedback after the call with Garmin support ?  thanks !
  • Update on my device. My wife let it drain to 0%. When she attempted to charge it, it stalled at 93%, She continued to wear it and then charged again about a week or so later. It sat overnight and did not charge (likely not connected well is what we suspect) then the next night it charged to 100%. Problem solved for now.
  • wonder how's the duration if still the same as previous or match what 100% should be  ? and also how's the next time with charge does still able to charge till 100% ?
  • I also have a similar problem. Just got my 255s music last week and it’s my first time charging it earlier today. The charging stopped at 84%. Tried to turn it off and turn it on and charged it again but no avail. The seller advised me to charge it again and leave it longer. Did it for 1hr 30 minutes but only 4% was added to be at 88%.
    I tried charging it again for the 3rd time, this time I turned off the watch (power off), and after an hour, it is now at 100%. Thank you for this tip! It worked for me.
  • This works!! I was stuck on 89%, pressed power and five minutes later I am at 100%!
