My forerunner 245 will not charge up. It is showing a blue triangle on the screen
I would try doing a hard reset of the watch - My Garmin Fitness Device Appears to Be Frozen or Locked Up
Then, if still a problem a factory reset, which would typically be doing this - Resetting All Default Settings
However, since you cannot get past the blue triangle, you can factory reset by using the Unprompted Reset method.
If after all of this, there is still no joy, contact Garmin Product Support.
