Weather temperature is completely wrong on the widget but everything else is correct
Hello,
I have a problem with weather widget on my Garmin. Temperature is completely wrong, at this moment it shows 12 degrees when the actual temperature is 19 degrees. The weird thing is that when I go into the widget on my Garmin and open hourly forecast, temperature for current hour is correct, but it doesn't show up correctly on the widget itself (on Home Screen). Syncing works just fine and I allowed Garmin Connect for my location 24/7. What could be the problem in this case? It's pretty annoying.
Thanks in advance :)
