If it is left on the elevation is incorrect by 50-100 meters. I always sync to strava which seems much more accurate, so it is not a problem with gps accuracy. If I turn correction off then elevation matches strava exactly.
This is a screenshot from the Connect website. I have a fenix 6 which does have the barometer, the FR245 doesn't have it, so I don't know if you'll be able to find any setting to disable it. Even for fenix 6 I don't think I could enable it for all future workouts. Probably it can be disabled / enabled only manually per workout :(
