Hi there,
I'm a 37yo male, 170cm, 103.6kg (very obese). Have been using Garmin Forerunner 245 Music and my VO2 Max is showing as 30 with Fitness Age 79. This was very concerning but figured I work a sedentary job, have put on a bunch of weight and wasn't doing much in the way of exercise that maybe it had got that bad. Over the past 3 weeks, I've been running a fair bit, eating better and dropped 3.8kgs - however this figure hasn't changed. I've noticed my runs getting easier (certainly not easy) but I'm doing 5km in around 32 minutes.
Could VO2 Max still be 30 or is something wrong here? Every run I've been doing lately has come up with "Performance Condition +16 or +20, Excellent!" around the 1km mark and I feel much healthier today than I did 3 weeks ago (still a long way from where I want to be but heading in the right direction). Every run shows the VO2 with the right arrow symbol (no movement). And I've been doing a fair few runs - have run 30km over the past 7 days (6x5km runs).
Lastly, if I do the calcs I've found online, I get the following:
Resting HR: 53 avg (past 7 days)
1) Max HR: 220-37 = 183
2) Max HR (Garmin Connect corrected somehow after a run): 187
3) Max HR: 205.8 - (0.685x37) = 180.5
I know Garmin use FirstBeat method but based on VO2 max = 15 x (HRmax/HRrest)
1) VO2 max = 15 x (183/53) = 51.8
2) VO2 max = 15 x (180.5/53) = 51
3) VO2 max = 15 x (187/53) = almost 53
I don't think it would be anywhere near that personally but I feel like it would be much higher than 30. Wouldn't it?
I have been running occasionally at lunch with some colleagues, another who is a bit taller but similar weight (slightly lighter), similar age, similar running pace etc. and his VO2 Max is 44.
Feeling a bit anxious with a fitness age of 79 and VO2 Max in the bottom 5% for my age. Is there some setting that I'm missing or do you think that it is in fact accurate and I just need to keep working at improving it?
