Hi everybody!
I use a 245 watch with software version 8.30. The creation of courses with Garmin connect and Komoot works well. Also, the synchronization of the courses with the watch works well inboth cases. When using navigation along such a course during an activity, the watch shows turn prompts. If the course has been created with Garmin connect the turn prompts will be super accurate. I tested multiple courses and the position error of the turn prompt is typically below 5 or 10 meters. But…
If an identical course is created with Komoot instead of Garmin connect, the turn prompts of the watch will be wrong. This is what happens, see pictures attached:
- A turn prompt typically appears too early although the GPS navigation is correct. See picture 1: Although there is about 250 m to go (which is correct), the turn prompt says: “turn in 93 m”.
- When there is still about 150 m to go, the turn prompt says: “turn now”.
- After this, even without really having turned, the turn prompt falsely indicates that the user is already on the next course segment and shows the distance to the next turn.
The pictures show that the GPS-based positioning on the course map is always correct. Only the turn prompts are wrong. To me, this looks like a software bug upon creating turn prompts for Komoot-based maps.
Anybody and idea? Anybody else more luck than me?
