How does Forerunner 245 give Prompts? (not 245 Music)
Hello,
I am a Suunto 5 user and was thinking of moving to a 245 as it seems easier to build and transfer complex workouts to it.
Does the 245 do prompts to bring you into HR Zones or warn you to slow down/speed up etc? If  so, how does it do so? Buzz? Beep?
I dont want to go to a 245 Music if possible.
Regards
U
  • If you do a structured workout and add HR/Pace alerts, the watch will beep/vibrate (*) and a full screen alert will be displayed on the watch. (I don’t use these a lot, but IIRC, the alert shows you your current HR/pace, and the color of the alert suggests whether you’re too high or too low.) You can also set alerts on the watch outside of a structured workout.
    (*) Beeps and vibrations can be enabled and disabled independently in the watch settings.
    Also, you can still get audio alerts with the 245 (non-music) but in that case, you have to run with your phone.
