Spotify Playlist Issues
For the past two updates the Spotify playlist successfully syncs without issues. However, the repeat or shuffle function is no longer working within the Spotify app. While running once the playlist reaches the end, I need to go into the Spotify app while running, keep pushing the back button to start the playlist over. Once the playlist starts over, the shuffle function does not work, and the playlist again plays straight through to the end and stops.
For trouble shooting I have tried the following: Removing the playlist and re-adding, also added a secondary new playlist, and the same. Remove and reinstalled Spotify, updated the firmware and software.
Also, with others the Bluetooth connectivity issues are also very annoying. Many other posts complaining about the similar issue. The issue is due to a distance from the watch to the headphones. When the firmware is updated, it seems there is a power reduction allow the Bluetooth radio to connect correctly. I have already RMA one watch thinking it was a battery issue, however it seems to be more related to updates as my second watching is having the same exact problem. Some updates are released which fix the issue, however we eventually get another which causes the issue again.
