Not displaying final time between 2 types of run for interval trainings
Hi Garmin support
Hope my English is clear enough to explain my problem.
I created a bunch of personal trainings, most of them with repeated intervals:
run + rest
my Garmin 245 used to display the final time of my run when switching to the rest interval
it's not the case anymore and at the end of my run it only displays the rest interval target
For example, let's say I run 400m + 1min rest, repeated 8 times
I don't see my final time at the end of the 400m, it switches automatically to the next step which is the rest interval
I have version 7.80 (fca3556) on my watch
are you aware of similar issue ? Or do I need to update my display config. I tried to find some options but no luck so far
Thanks for your help
Raphael
  • Hey Raph.
    I've had the same problem since I like to see what my final time is. However, I came up with a partial solution which is, essentially, adding the "Last lap time" data field to the screen so that I am able to see it just after finishing the lap.
    Nevertheless, as to find a solution so the screen shows automatically your final time, I have no clue.
    Hope you find it useful!
  • Thanks Jon
    I'll try that as it looks like the best solution Slight smile
