Hi there,
My training pal: Forerunner 245 v7.80
When I charge my watch it shows the charging progress for some time and then stops. For e.g. today I've started to charge from 6% of battery and was able to reach up to 65% when it stopped but the thing is when I've disconnected it from power source it shows 100%. It happened with different sources of power.
The question is if it has stopped charging at 65% or just indicator hanged and why?
It is not because of the latest firmware as it started to happened more often even couple versions of firmware before.
I can record my 7h long activities with everything enabled and at the end of the day with 70% battery level but I'm still not sure if it is something with the battery I should care about when I still have shop guaranty.
BR,
Jakub
