Setting a goal for the long-run
I set a goal this morning (half marathon at a certain pace). During the run it showed the half-marathon time. But then I had to run back home for several 100meters. Now at home I can't find the half-marathon time, only the time for the 21,60km. Where can I find the half-marathon time?
  • Did you hit the lap button after you completed the half, or program the workout to have a 21 km segment and then a new lap for the cooldown?  If so, you should be able to find it as that lap time, but if neither the program nor you indicated to the unit that you were done that lap, you may just have to dive into the data and find either the point on the map where the half ended, or the time point where you perhaps stopped for a moment and threw your arms in the air triumphantly.
