Training load focus (When together with edge 530)
Hello all,
I have a edge 530 which have the training load focus. From specs of the 245 I understand that it doesn't display training load focus (on the watch?)
But via physio true up, would the exercises made with the 245 add up to the training load focus on the edge 530 (being visible also on the garmin connect)?
Thank you by now
  • AFAIK, that feature is sync via TrueUp, but ONLY as long as the devices synced up support training load focus.
    So Fenix 6, FR745, FR 945, edge 530/830 and so on will add up - FR245, Edge 130 and so on won´t.
  • I have the same set up. With True up activated on both devices, excercises on Fr245 will add to Training load focus correctly, but it is only visible on the edge device, though. You will see the training loads on the graph in the device, but you will not see training load focus on garmin connect app.
  • great, totally enough for me.
    Today I have F6S sapphire that I bought for "cheap" used. I don't need all those functions.
    Having the training loads merged on one device is enough for me.
    Thank you a lot
  • JFox, also confirm this! Thank you!
  • Stand stand corrected. Always good to learn. :-)
  • I use the FR 630 so I was wondering if there is the same problem with the FR 245. Does the load focus on your edge 530 also include your running activities? In my case the running activities have no impact on any of the "loads" (anaerobic, high aerobic, low aerobic impact). Only the total of training load (last 7 days) will be updated.
