Had 245 before and loved it. Only problem was i had the white spots on screen so they replaced it with a new one. Got it this week and went out for a run today but gps won’t turn on at all. I did a hard reset and it did not help.
Do you mean you aren't seeing the indication that it is ready? First make sure you have GPS turned on correctly - Forerunner 245/245 Music - Changing the GPS Setting (garmin.com). Then sync using a USB cable and Garmin Express. Then leave watch outside with a clear view of the sky for 20 minutes or so. Go for an outdoor activity to test.
It seems there was an issue:
					Yes, gps is on correctly. I synced it also with Garmin Express. I will try to leave watch for 20 mins outside. I just didn’t have to do this with my first 245. I wonder why
Maybe, but that issue was more related to offset tracks on the map, which you didn't mention in your post. I would just sync to Garmin Express again and see how it goes on your next run. Let us know if there's still an issue.
You might be having an issue with the CPE file on the watch. This can sometimes happen if the watch hasn't locked on to GPS in awhile, causing the watch to not acquire satellites. You can try the following steps and usually it will resolve the issue.
					THANKS! THIS DID THE JOB FOR ME.
