I have a problem with my Forerunner 245m. For almost three months now I have noticed something that is slowly getting annoying for me:
If I connect the clock to the PC via a USB cable, it must not be moved a millimeter because the connection is immediately broken and reconnected again.
This is particularly tedious on the PC, as music or data transfers always break off. At first I thought a new cable would solve the problem. Even with this (original cable) I couldn't solve the problem. It didn't work with another friend's either. In fact, it is not the PC itself, as this error also occurs on other devices.
The watch is very well maintained, has no scratches and especially on the USB socket you can see NOTHING on the outside! No idea why this problem occurs.
Has anyone experienced something similar or a tip?
Thank you so much!
