Software Version 5.50 - Forerunner 245 Series - Live
Clarification: For those of you who received 5.40 this update only includes the following:
Addressed an issue that caused VO2 Max update and Training Status to not update
If you have not yet received Version 5.40, then the update will include the above, as well as everything that was previously in 5.40 which I have included below.
Update can be downloaded through Garmin Express or Garmin Connect Mobile pending the rollout schedule.
- Fixed an issue that caused CIQ watch faces to display 0 calories.
- Added improvements to prevent dropped phone connection.
- Other minor improvements and bug fixes.
- Fix an iOS reconnection issue on some phones.
  • after each lap when I have auto lap feature set, it is displaying avg pace in lap screen always as 0:00 (I'm using 0.5km laps)
  • This bug from 5.20 is still there
    "Updated the main workout data screen to indicate High, Low, or In Range for the current target."
    This works when the activity background is set to white, but not when it's black
  • I was under the impression that this feature was reserved for the 745/945.
    Is this available only for workouts? Or is it available for non-workout activities as well?
  • During a workout with a heart rate / pace / cadence(?) target there's an additional data screen with a gauge that shows when you're over, under or at the target. When you cross over the target boundaries there's a little text notification in the middle telling if you're shooting high, low or in range.
    (The bug is that the text is always white, and I guess the notification background is white when activity bg is black and vice versa, so the text color seems to be hard coded and doesn't mind the bg setting)
    0 Former Member in reply to Former Member
    i have the same issue...battery drain is high. used to charge it every 6 days-1week, with 3-4 hours of run. now it's lower than 20% in 3 days.
    therefore i see no sign of hear rate in gamrin connect app: still showing the hr at the moment but no daily variation nor max or min Hear frequency.
  • 5:50 is the worst upgrade I have seen. Must reset watch because battery drain. No SpO2 in sleep. And 178 puls when easy jogging in 8:30. The only good is that the networks error is gone when sync Spotify/Deezer. Lucky me I have the Garmin HRM-Tri.
  • Hi guys
    Im not sure exactly how to check if my watch is APAC
    I tried to check the number in the .xml file but this file I actually cant open - any other way I can check if I have an APAC device?
    Im guessing I do since I live in Taiwan and watch was originally in chinese box is in english though
    I had no previous idea of this unfortunately
    Trying to update my firmware to have updated recovery hours feature taking into account sleep and stress
    However followed the instructions and doesnt work
    I copy all the respective files into Garmin folder and GarminSW Folders etc
    They show in the folders as being copied over
    When unplugging device nothing happens no install or prompt
    When plugging device back in seems the files I copied over are gone and no install
    I checked about on watch and still shows Im running 5.0 although I would love the 5.32
    Any idea why this happens? I checked similar posts and looks like people have the same issue but I didnt see any solutions
    Oh - if it is an APAC device does that mean it cannot be updated with current firmware?
    The firmware doesnt specify APAC or ROW?
    Thanks a lot any answers would be great
    Currently 245M is still on 5.0
    Is it worth it to update?
    Does the recovery time feature really improve? Mainly want that feature as its a feature on the new 745
    Thanks a lot
  • Well they still working on the sleep tracking update that's fit in with improved recovery times, so that feature is not fully baked as yet. 5.5 has some other cool features like TrackMode for example which you might want.
    Also, why are you updating with 5.32 and not 5.5? 5.32 had some biggish bugs that 5.4 fixed, and then 5.5 fixed some critical bugs on 5.4.
  • Thanks for the reply brother
    Well basically I cannot update my watch
    I try it manually on a windows PC and follow all the instructions
    Upon adding the file to my watch etc when I unplug the watch nothing happens - and when I plug it back in there are no files copied to the watch + no update
    Not sure how to make it work
    Havent manually updated firmware this will be my first time watch just 2-3 months old
    Not sure if I have an APAC version
  • Where do I find the 5.5 update? Is it also available for 245M?
    I only seem to find the 5.32 update
