Your initial measurement was obviously wildly overestimated, and it's gradually correcting itself with more data.
Are you looking at the corrected Vo2 values on Runalyze?
For aerobic improvements…
A max of 199 to 203 would be accurate. I'd aim closer to the 203 at your age.
220-age = 203 -> generally accepted max without correcting for age
Or
211-(0.65×age) = 199 -> more accurate after…
For aerobic improvements in training, you need to stay in a zone that allows the body to utilize oxygen for energy (as a primary energy source). In other words, training just below to just above your LTHR should elicit the most benefits.
Of course you'll make aerobic improvements training in other zones, but as a secondary adaptation to the goal of the session.
What has you're training looked like? Distance, pace, hr, time in zones...
As a side note, I'm curious if you are currently able to meet the Predicted Race Times for a 5km, 10km, half marathon distance.
They may overreach on the estimate a bit, but I'd think if your Vo2 was what you think it is, those race times should be easy to hit.
Hi, just like you said, my initial measurement will probably be overestimated but I think my VO2 max could be in the high 50s. I'm 17 years old and did a lot of sports when I was younger.
What do you mean with the corrected value? The graph from Runalyze is the "Effective VO2 max" graph.
So I started running about 4 months ago but I almost only did 5km tempo runs. This week I started a half marathon plan so my training would be more varied and I have a goal to work to.
This is the plan I'm following: https://www.roadrunnersports.com/blog/8-week-half-marathon-training/
Here are some activities for you to look at (I do use the Garmin GRM-Run to get accurate hr measurements):
10K I did yesterday: https://connect.garmin.com/modern/activity/5256795861
A little fartlek session: https://connect.garmin.com/modern/activity/5227612894
And a 5K run: https://connect.garmin.com/modern/activity/5099539667
I think my Race Predictor times are doable but they would require a lot of training. Here are my predicted times:
5K: 19:21
10K: 42:00
My current records are (keep in mind I haven't run for my best time yet, I just go out and sometimes get a PR "on accident"):
5K: 23:21
10K: 49:25
Also sorry for my bad English, I'm Dutch ;)
You are not in the high 50's.
Your 5km and 10km times are much closer to a low 40s Vo2.
4 months of running in a zone that was far to high for your current fitness. And 17 yrs old with an athletic background is not enough for a Vo2 in the high 50s. The prerequisites arent there.
The predicted race times on your Garmin are what you could expect to achieve at the current Vo2. If you truly believe you have it, go after thos times. Do the 5km, 10km and half over a couple weeks and see how you match up.
If I had to guess, you wont even come close to a sub 20 5km (a pace of <4:00 /km) or 42 min 10km ( a 4:12 /km pace)
Runalyze breaks Vo2 down into several numbers depending on what section your looking at. You want to find the corrected Vo2 values.
My 5K and 10K times might be "closer to a low 40s Vo2" but those are not my best times. My 10K easy run yesterday was 20 seconds slower than my 10K PR which again shows that I can do a lot better regarding my 5K and 10K times.
Also, Runalyze gives me an effective VO2 max (VDOT) of 51 for my 10k run yesterday. Since VDOT is almost always lower than your actual VO2 max, it would be higher than 51.
Do a 10km TT on monday and see how you stack up*. At 51 Vo2, you should finish your 10km in 40-41 minutes.
That's all the advice I can provide.
*You should easily hit the predicted 10km time on your Garmin at a 51. A 42min 10km would have a predicted Vo2 of 49ml/kg/min.
I will stick to my training plan for now but after I've run my HM, I'll do a 10km TT.
hi Mr_BananaPants,
care to verify your heart rate zones on all Garmin Platforms ?
check Garmin Connect Web, Garmin Connect Mobile and the Watch
sync again from within Garmin Connect Web
happy & safe sporting
Hi
My heart rate zones are set in my watch, the Garmin Connect app, and the web version of Garmin Connect.
hi,
and they are the same
guess you had them setup in Runalyze
sometimes after a firmware update these settings go wrong
no harm done checking
while busy checking also check max hr setting
They are all the same. My VO2 max didn't change because of a firmware update. My max hr is also set correctly on all platforms.
