My cadence has stopped showing in Garmin Connect, just nothing there on the graph. I have turned my watch off and on again, but anyone have any ideas?
Just to add to the choir here: My cadence field on the run screen on the watch stopped working with the 7.20 firmware update, and I'm having the same pace dropouts as reported by others. In the connect…
This first week of September 2021 my 245 stopped showing cadence while running, and run pace is sporadic. There was an update prior to this. Version 7.80
I have the same problem. However, I've found that turning the watch off and back on again just before I run resolves the problem. If I don't do this, then after 5 or 6 activities being logged, it stops…
Well they clearly have fixed it hence the 8.30 software rollout.
I was having trouble getting both body battery and cadence data recorded. Then I deleted a lot of the .fit files from my Forerunner 245 and both of these parameters immediately came back. A simple reboot without deleting these files did not do the trick. My guess is that the problem was due to storage conflict.
