I just upgrade from a much older Garmin Forerunner that had a power button, but I do not see one on the Forerunner 245 Music. Is it no longer necessary to power off a Garmin Forerunner?
Thanks
Thanks
Hold down the light button for 15 seconds until it powers off. Same as restarting the device in the manual: Restarting the device
Typically done when screen locks up or some other issue. Normally, not really necessary, unless you won't be using it for an extended period.
That works, thank you!
Not necessary to hold power/light button for 15 seconds. After 1 second, a menu appears with the off icon selected. Select it with the upper right button.
It is only necessary if the unit has stopped resonding, in which case the menu will not appear..
Forerunner 245/245 Music - Restarting the Device (garmin.com)
